id a 460 year?
Old Apr 15, 2004 | 04:14 PM
keh's Avatar
keh
Question id a 460 year?
have an older motorhome with a unknown 460 in it. a tag on valve cover reads\
E1UE 9C 485-V8 Engine family 7./7.5 E ERG/A\P PLUG ASF42-Timming 8 btc
my question ,is this an 1985 engine ? or how would one best find the year of this motor? thanks
Old Apr 16, 2004 | 03:53 AM
ludis's Avatar
ludis
Sounds like an 81 van engine. (E1 ==> 81, U ==> van)
The 9C485 is probably the part number of the sticker.
Old Apr 16, 2004 | 10:41 AM
Mil1ion's Avatar
Mil1ion
You have to check the casting codes to determine what it is & when it was made.
The E1 only means it was designed for that year, but could apply to later years.That could be just for the sticker.
The casting codes on the block are on the side of the block in behind & above the starter.
On The heads just below the sparkplugs on the head lip.
There are also casting numbers on the intake manifold.
Old Apr 16, 2004 | 02:43 PM
scroob's Avatar
scroob
Also, you can't really trust a valve cover sticker unless you know beyond a doubt that the cover has never been changed.
Old Apr 16, 2004 | 07:45 PM
keh's Avatar
keh
thanks for the input, i shall crawl under the rig this weekend and pull the #'s off the block
