View Poll Results: 4.2 engines
____
50.00%
____
50.00%
Voters: 2. You may not vote on this poll
spark plugs and wires
Old 04-12-2004, 02:33 PM
kidice's Avatar
kidice
kidice is offline
I need help changing out spark plugs and wires i have 99,450 mile on my truck......I've heard that i should stay with moter craft plug if so should i go with platinum or regular moter crafts someone also told me about denso plugs and using NGK or ACCELL wires. someone please help me out because don't want to put the wrong thing in my truck.
Old 04-12-2004, 02:43 PM
Bob Ayers's Avatar
Bob Ayers
Bob Ayers is offline
Stay with Motorcraft double platinums, or the new "fine wire" platinums.....You're POLL isn't set up right....
Old 04-12-2004, 04:28 PM
BrianA's Avatar
BrianA
BrianA is offline
Howdy and welcome to FTE! I'd vote, but I'm not sure what I'd be voting for
You might want to edit your poll or tell me what you want and I can do that for you.
FWIW: I used and suggest using OEM replacements: Motorcraft wires and plugs.
They have both worked very nicely for me.
Old 04-14-2004, 10:30 AM
Busa01's Avatar
Busa01
Busa01 is offline
It's hard for me to get Motorcraft plugs here and the dealer charges 8 bucks each. Autolites for 1.29 work great, you just have to set the gap before you install them. Again, motorcraft wires, expensive and hard to get for me. I upgraded to Taylor SpiroPro wires. They are far superior and only 79.00 for a set. Accel's are a semi decent upgrade as well, but quite generic from an overall performance standpoint.
Old 04-14-2004, 03:05 PM
kidice's Avatar
kidice
kidice is offline
thanks on the info on the spark plugs and wires I think I;ll get the taylor wires
Old 04-14-2004, 04:01 PM
Busa01's Avatar
Busa01
Busa01 is offline
Yeah, any color you want too!!!
http://www.taylorvertex.com/spark.html#spiro
They don't make them specific for our trucks so you have to get the universal kit and cut them yourself. Takes about 2 hours.
Old 04-14-2004, 04:20 PM
strick4.2's Avatar
strick4.2
strick4.2 is offline
new plugs and wires huh........while ur in there change ur voltage regulator...just to be safe....
Old 04-15-2004, 07:13 AM
Busa01's Avatar
Busa01
Busa01 is offline
ok Joe. I don't remember if you were here to remember that joke Strick, were you? That's an oldie but goodie
