Sponsored by: Real Truck
speedo calibration
Old Apr 12, 2004 | 01:12 AM
569104's Avatar
569104
Question speedo calibration
I pick up my 04 f350 6.0 6 speed cc lb lariat srw wednesday. one of the first mods i will do is a 4" lift and 315/75-16 tires. the truck comes with 3.73's, and 265/75-16 tires and with my calculations 4.10's will put the final drive very close to the stock #'s. My ? is....will I need to install a "truespeed" to get the speedo correct or since the final drive is very close to the same will the stock computer adjust to the slight difference? Thanks in advance for your help!
Old Apr 12, 2004 | 12:21 PM
Oldchap's Avatar
Oldchap
I put BFG 295s on my 1999 F-250, replacing the General 235s that came with the truck, at about 90,000 miles. The speedometer was incorrect by about 7% (measurements per GPS) but the computer doesn't seem to care. Everything works fine - I get stuck in the mud less, the tires have that awesome look, and I enjoy about 10% better fuel mileage!
OK, so I have to downshift a little more often when needing to quickly excelerate to pass, but I don't mind - if I did, I wouldn't have bought a manual transmission.
You situation may vary.....
Old Apr 12, 2004 | 02:47 PM
CmprSpecial's Avatar
CmprSpecial
Ford can do it and they usually don't charge very much. There is a value that can be changed based on the circumference of the tire.
