Error Code P1443
Old Apr 8, 2004 | 04:09 PM
87lx's Avatar
87lx
Exclamation Error Code P1443
I am new to this forum but have been reading through it for a while and thought I would share my experience so far with this problem. I thought there was already a post regarding this error but I could not find it again.
The check engine light has been on in my 96 XLT 4.0 4x4 for a while and I just recently decided to fix it. I had AutoZone pull the code and it pointed to the # 1 O2 sensor which I replaced. Actually I could not tell which one was the number 1 sensor so I tried one and then the other, the light came back on after both. I had them pull the code again which pointed to the Evaporative Emisson Control System (see below). I replace the assembly $100.00 and the O2 Sensor was $50.00. The light has stayed out for 2 days now so we shall see.
P1443 Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault.
Old Apr 8, 2004 | 04:35 PM
Rockledge's Avatar
Rockledge
Welcome to Ford Truck Enthusiasts!
Hope your problem is fixed. This thread has some info on the P1443 Code: EVAP Code P1443 Thread
P.S. The codes were cleared after the repairs to your truck, right?
Old Apr 12, 2004 | 08:06 AM
87lx's Avatar
87lx
Rockledge thanks for the info on the thread. The problem is not fixed the Check Engine light came back on today on my drive into work. I did clear the codes by disconnecting the battery. I guess I will make another trip to AutoZone and see what it is this time. I think the on board computers are tied into the auto parts point of sale system as well as the dealers because it seems like I have to spend about $500.00 on any repair before its fixed!
Old Apr 12, 2004 | 10:39 PM
maroon splash's Avatar
maroon splash
you can take the the hose off spray carb cleaner in it. take a jumper wire from the battery put it on each post of the switch. you will hear it pump. keep spraying cleaner in it till it pumps real fast. i cleaned mine about 2 mo's ago and no more light.
Old Apr 12, 2004 | 10:46 PM
hreed's Avatar
hreed
I had the 1443 on my 95 Ranger 3.0, and it was the purge valve. If you look at the carbon canister hoses, and follow the one with the valves back a little, there are two valves from the canister to the manifold. One is the purge valve and the other is a "thermistor". I replaced both, and the problem went away.
Old Apr 13, 2004 | 01:38 PM
87lx's Avatar
87lx
I replaced the whole assembly shown below. Hreed are you referring to parts not on this assembly?
Old Apr 13, 2004 | 09:31 PM
hreed's Avatar
hreed
Those are the parts. The bigger one is the purge valve and the smaller one is the thermistor. You might check the voltages at the connectors to make sure it is not an electrical problem.
Old Apr 13, 2004 | 09:33 PM
hreed's Avatar
hreed
Also you might put a vacuum guage on the engine to make sure there are no leaks. If one of these hoses is leaking, that might set the code. Good luck.
scooterspal
16
Jun 23, 2015 05:21 PM
sirren
Jun 26, 2014 08:25 AM
Roguespirit
Oct 10, 2003 12:00 AM
timdco
Apr 11, 2003 11:53 PM
macwho
Aerostar
Aug 26, 2002 08:54 PM
