Anyone got any URLs for rear brake shoe replacement?
It's been a year since I've had my truck, and I've never gotten around to putting new brake shoes on the rear. The one on the passneger side has a cracked friction material surface and the brakes make a grinding noise (it's not metal on metal.. just that the friction material is loose)
I want to remove them, but I've never done it, and I don't want to screw anything up. Are there any good sites with PICTURES that document how to do this? The Haynes manual I have is a little ambiguous.
It's funny.. of the 8 other vehicles I've owned, they've all had rear brake disc/pad setups.
I have already purchased the pliers and something with a screwdriver handle to do this job, so I think I'm ready to go. I just need pics to see what I have to do
Basically, I have the two tools shown below (not the cylinder hone)
Ok how good are you at putting things back together that you took apart? Get the rebuild kit clean the guts of the drum off with some brake cleaner and take a few snap shots of your own the drum should pull right off and bingo there it is. Look at it for a minute and that will give you a good idea. What always works with me is when I can for every part I take off i put the new one right back in place you will not always be able to do that but sometimes you can.
