Vacuum/Emissions on a '79 Canadian F-250 4x4
I could sure use some help locating a diagram or guide on the vacuum and emissions equipment of this beast.
I've looked through the Autozone diagrams, and can't find anything that seems to match the equipment that is left in the truck.
And, when the engine was rebuilt by the previous owner, they cleverly painted over the emissions sticker on the valve cover.
There are several hoses plugged up or just left dangling.
Here's what is in the truck that I can identify now:
400, 2150 w/vacuum choke and EGR
PCV, 5-way splitter on the back of the manifold with 2 ports plugged up
A black-painted coffee-can attached near the radiator with a hose hanging from it.
Valve on the air cleaner attached to the manifold (doesn't appear to be working).
No smog pump
EGR valve was plugged along with a port on the carb that I believe is the EGR port. I connected the two without any noticeable change.
The truck originally had cruise control, but all of that equipment seems to be gone.
The only items that were connected when I got the truck were the brakes, air cleaner, and dist.
Can anyone help an overheated Arizonan tame this Canadian truck?
No smog pump
I could sure use some help locating a diagram or guide on the vacuum and emissions equipment of this beast. I've looked through the Autozone diagrams, and can't find anything that seems to match the equipment that is left in the truck.
PCV, 5-way splitter on the back of the manifold with 2 ports plugged up. A black-painted coffee-can attached near the radiator with a hose hanging from it.
No smog pump EGR valve was plugged along with a port on the carb that I believe is the EGR port. I connected the two without any noticeable change.
...how much of it do you need to get working?
ash
['Woo.']
Originally Posted by ashvalentine
Paint will float on top of paper. You can try and scratch off the paint on the right side of the calibration sticker (passenger-side valve cover, front). That will give you the exact calibration, although there are only two basic schematics for the HD: one for A/C, one for non-A/C.
Also, the sticker is on the driver's side valve cover. The way the truck is set up, and it being a Camper Special, I am assuming it would have the HD config (sans A/C).
That's a hot air choke tube. If you still have the carb tag, and I'm right about it being an 49S HD auto, the carb id should be D9TE (9510) - DTA or EHA.
If it's on the passenger side and it's got two connectors on top that the vacuum reserve can for the Venturi Vacuum Amplifier. The VVA should be on top of the motor, next to the valve cover, passenger side rear. It should have five vacuum connectors. It helps control the EGR.
If it's on the side on the air cleaner, that's a TVS switch for the bypass valve. You shouldn't have one for and HD setup. If it's in the lid of the air cleaner, that's the bimetallic switch that switch that controls where the heat stove diverter is working on not. I
It sounds like you're missing lots of stuff. Do you have two PVS switches (one three port, one two port) in the upper radiator hose intake? You should have a throttle kicker too.
ash
['Woo.']
ash
['Woo.']
It passed emissions here in the state I described above, so that isn't a problem. I'd just like to get it running as smoothly and efficiently as possible.
Your calibration code is 7-73-R10.
Here is your tune-up & settings info.
http://www.clubfte.com/users/mil1ion...tionSpecs2.JPG
Some of the paint comes off, but all you end up with is clean white empty boxes where the printing should be. Also, the sticker is on the driver's side valve cover. The way the truck is set up, and it being a Camper Special, I am assuming it would have the HD config (sans A/C).
I do not seem to have those switches. As for a throttle kicker, there is a solenoid (no dashpot), that seems to work ok.
Well, the truck runs, but very inconsistantly. I am constantly re-adjusting the carb whenever the temperature changes here.
Ok, today's blue plate special is a 3-for-1 (pardon slow loading):
1977, no PVS:
http://home.earthlink.net/~sigyn/7-7X-R0.JPG
1978, one or two PVS:
http://home.earthlink.net/~sigyn/7-7X-R10.JPG
1979, two PVS. Part numbers!:
http://home.earthlink.net/~sigyn/9-74J-R0.JPG
Oops. Choke pulldown should be .175 there. You'd probably be able to get away with .140
Your distributor will probably need adjusting whatever you do.
ash
['Good luck.']
Thanks for the diagrams ashvalentine.
Ok, a follow-up.
I was able to get the paint off the emissions sticker. The places where I had removed it and was left with empty boxes... were supposed to be empty (silly me). I was scrubbing the valve-covers while replacing the gaskets, when I hit it with a scouring pad. Worked wonders.
Anyway, I've put up a picture of the emissions tag in my gallery. The code at the bottom of it reads: D6AE-9C485-AAC with a 6-219 over to the right of that.
Are the diagrams and charts that have been indicated in this thread, apply to this spec?
Thanks again guys.
Ok, a follow-up.
Thanks again guys.
AsianSpanker
'80-'86 FAQs (Frequently Asked Questions)
19
03-23-2020 10:52 PM
crazy96863
07-24-2015 11:56 PM
crazy96863
07-24-2015 10:09 AM
