Tonneau Cover - A Good Idea?
Don’t know about the Auto Discount brand, but I installed my Truxedo brand soft tonneau cover in about 15 minutes. Installation was easy. Buy a tonneau for looks or to keep things in your bed out of sight, but do not buy it if you are only looking for improved gas mileage. I check my mileage at every fill-up and I get the identical mpg with or without the tonneau.
Gas milage, you wont see much of a gain. The weight on the back end will help with handling.
-'s have to take off to haul items. limit's space in bed
+'s lockable security for goods, looks.
There's probably more, but I'm brian farting. I have one on mine at the moment, I switch back and fourth between that and a toolbox.
A cover will save you an average of 5% over all and 10% on the highway. Go to www.truckgadgets.com and they have a report from ford aerospace div. that ran wind tunnel test on a 97 f150. it looks like it pays off pretty fast at todays gas prices.
You should check out www.undercoverinfo.com. Sweet cover and about half the cost of any other hard cover.
Jon
Jon
Fuel mileage will probably increase a bit. I used to have a 96 dodge and the mileage increased by 1 - 2 mpg. The ford I have now has one as well and it is hard to tell a difference (because it burns so damn much anyways!!). These covers were/are 'low rider' tonneau covers and requires 2 people to remove.
I bought an Extang from here:
http://www.truckxpressions.com/truck...fftonnoIII.htm
Great looks, easy install. Had a problem with the fit initial and Extang went WAY above and beyond with helping. They shipped a new cover and side rails at NO charge and did not even ask for the old ones back.
Only thing is when new the fit is TIGHT and I had to loosen the rails to get it on. Over time though with driving and wind it lossens up just enough to make taking on and off easy.
THE BEST cover i've seen by far-http://www.accesscover.com/
My step-dad has one of those soft tonneau covers on his '03 S-crew that snaps onto these rails and it sucks *** to put on. its not bad once it's worn in and you figure out the best orders to snap the snaps in. And then you have to worry about putting those braces somewhere.
the link i posted i saw on a TV show one saterday, Trucks! mabey. the only problem i see with that is how far those side rails stick out, might be a problem if yo haul big things, like a fourwheeler or something like that.
