Same carb, different engine?
Old Apr 4, 2004 | 07:46 PM
Polkat's Avatar
Polkat
The original carb on my stock '71 302 is an Autolite 2100 with the 1.08" bores. I'm not yet sure how it's jetted. This is a 3 speed manual truck, and I'm swapping over to a C4. The present 2100 has no kickdown linkage, so I found a 2150 with 1.21" bores that has the linkage. I'm about to rebuild this 2150 for the 302.
Here's the question: I assume this 2150 came off a 351 of some type due to the bigger bore size. Should I assume that by swapping it to the 302, I'll need to do some kind of jet change? Anyone have a suggestion about jet size if necessary? Is the 1.21" bore size too big? Thanks for any help!
Old Apr 4, 2004 | 08:25 PM
LxMan1's Avatar
LxMan1
It should be fine. The larger bores will draw in more air so more fuel will required as well.
I wouldn't change anything until you have tried it to see how it runs.
Jimmy
Old Apr 4, 2004 | 11:34 PM
Polkat's Avatar
Polkat
Thanks Jimmy, that's how I was thinking about it. I'll try it first!
wallysF100
Jan 8, 2016 08:48 AM
wallysF100
Jan 4, 2016 06:44 PM
hedgeapple
Sep 11, 2015 06:56 PM
bulletsneverlie
Apr 26, 2009 11:02 PM
samahi72
Feb 13, 2008 11:19 AM
