question about fog lights on front bumper - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Reload this Page >
Old 04-02-2004, 08:20 AM
nheffelf
nheffelf is offline
nheffelf is starting off with a positive reputation.
b2 Tim, might I ask what type of fog lights you put in. Also, were you able to install them into the opening in the stock bumper or not.
Old 04-03-2004, 08:49 PM
b2_tim
b2_tim is offline
b2_tim is starting off with a positive reputation.
Fog Lights
I went to Auto Zone and bought a kit of two small rectangular lights. They are about 1.5 "by 3". I looked at my bumper and decided that the best place to attach them was in the center of the plastic bumper piece. I attached them to two existing plastic tabs that are in the center lower openings of the bumper, thank you Ford. Then I grounded them to a near by screw, and ran the positive line up to the under hood relay box on the drivers side. My truck had a spare socket for charging a trailer battery. I used that socket to wire up a spare relay I had for the lights. They only draw about 8 AMPS. Now the lights only burn when the engine is running. They will not burn in accessory mode, which is a good thing for drive-in theaters and the like. I aim them low so I can see the ground in front of my bumper, necessary if I go off road.
Old 04-04-2004, 01:12 AM
BrianA's Avatar
BrianA
BrianA is offline
BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.
FWIW, I did the same thing. Used the existing holes in the bumper and drilled thru the plastic part on top of the bumper, centering the hole to mount the lights. Worked like a charm.
Old 04-05-2004, 07:25 PM
Jimmy Dean's Avatar
Jimmy Dean
Jimmy Dean is offline
Jimmy Dean has a very good reputation on FTE.Jimmy Dean has a very good reputation on FTE.Jimmy Dean has a very good reputation on FTE.Jimmy Dean has a very good reputation on FTE.
Can someone please post a pic of theirs? I would like to see the fit and finish on it.
Old 04-05-2004, 08:21 PM
BrianA's Avatar
BrianA
BrianA is offline
I added one to my gallery. It was almost dark when I took the photo. I'll get a better one when I get a chance (in daylight next time).
Old 04-05-2004, 11:50 PM
b2_tim
b2_tim is offline
Wish I had a digi camera
Those look nice Brian. I put mine a little lower, in the holes where air comes in the bottom of the bumper. At least that is how my 2003 is set up. I got a surprise after hooking them up. Since they are some what recessed into the bumper, there is some light spillage back onto my aluminum AC condenser. This makes my front end behind the grill glow, kinda cool, the way it turned out.
Old 04-06-2004, 04:43 PM
nheffelf
nheffelf is offline
looks good
Hey thanks for the help. I like your idea. Maybe I will let you know how mine turns out.
cadillacmob
39
01-15-2019 11:00 AM
VFRcanada
2004 - 2008 F150
08-23-2011 09:58 PM
bajaron
1999 to 2016 Super Duty
12-14-2007 04:08 PM
Fordbronco95
10-17-2007 10:42 PM
tims01
01-03-2007 12:02 AM
Quick Reply: question about fog lights on front bumper
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
