msd blaster 2 coil
Old Apr 3, 2004 | 11:40 PM
iamaguy1357's Avatar
iamaguy1357
Question msd blaster 2 coil
I have a 88 f-150, 302 fuel injected, and i have bought most the performance parts i can find for it, and i just bought and installed new accel 8mm plugs for my truck, and i was just wondering if i could use one of these msd blaster 2 coils to give it a better spark or if i needed something else. So what im saying is, can i use this msd coil by itself without using anything else, or do i need something else for this coil to work. Thanks
Old Apr 3, 2004 | 11:52 PM
EPNCSU2006's Avatar
EPNCSU2006
You can run just the coil. I did that for a couple years on my truck before I got a 6A box. MSD has an E-core coil that will mount in the same place, and plug right into the wiring.
Old Apr 4, 2004 | 12:07 AM
iamaguy1357
thanks, it was a question i needed to ask.
And is it easy to install. Or should i get help with it
Old Apr 4, 2004 | 07:33 AM
EPNCSU2006's Avatar
EPNCSU2006
It's easy - 4 bolts, and plug in the wiring harness and the wire to the distributor. Not hard at all.
