Squeaking belt
Old Apr 3, 2004 | 06:03 PM
pharney's Avatar
pharney
Squeaking belt
I have a '93 Explorer XLT with everything. A little while ago the belt started to squeak. It almost sounds like geese or a seal. Anyways, I've replaced the belt tensioner and the belt, and, while it has improved the overall performance, the squeak is still there. Has anyone else ever gotten this?
Old May 25, 2004 | 07:18 AM
rburtz's Avatar
rburtz
I just had this start up on my 94 XLT. My problem sounds like the altinator bearing is starting to fail. Try to pinpoint the problem by trying a few tests.
  • Does it get louder when you turn?
  • Does it get louder when the engine revs?
  • Is the squeak present when idling (not in gear)?
  • Can you find the general location under the hood where the squeak is coming from?
Old May 25, 2004 | 08:11 AM
srercrcr's Avatar
srercrcr
Another of my high tech solutions.......
Cut a piece of garden hose about 3 ft long, use as a stethoscope....point to exact locations....STAY AWAY FROM THE FAN!. I suspect a bearing.
Old May 25, 2004 | 02:13 PM
87 XLT's Avatar
87 XLT
I also have a high tech state of the art mechanics stethosope/garden hose. Works great. If necessary remove the fan & shroud & take a listen.
Old May 27, 2004 | 12:31 AM
archer1's Avatar
archer1
Unplug the alternator and see if squeal lets up and /or goes away. Chances are you have a bad bearing in the alt. Replaced mine due to very loud squeal...
88_F0RD
13
Apr 4, 2014 04:55 AM
robinsonpowerstroke
49
Apr 17, 2013 09:29 AM
danpayton
Apr 7, 2009 07:29 AM
murrell
2004 - 2008 F150
Mar 15, 2007 06:22 PM
spoon059
Mar 5, 2003 08:39 PM
