Overhead Console and Gauges - which ones?
i'll post more on this tomorrow, but in short, i'll have spots for 4 total gauges in the overhead console i'm building. one spot will get my aeroforce interceptor, and 2 others will be pyro and turbo. i'm going with the autometer "Ford Match" ones that Clay carries: Ford - 99-03 Super Duty 7.3L - Gauges, Electrical & Lighting - Gauges - Autometer - Ford Factory Match - Riffraff Diesel Performance
i'm thinking HPOP for the last one. i'll have the optional fuel pressure sender for my AF wired into it, so no need for a standalone fuel pressure guage.
any votes for anything other than HPOP?
Thanks!
Thanks!
No need for a stand-alone injection pressure gauge either; you can (or should be able to) read it with the Interceptor. Same with boost. I would skip the fuel pressure option for the AF and put that money into a stand-alone fuel pressure gauge. Hmm, surprised he doesn't have a Ford match coolant temp gauge. That would be my choice for #4.
I'll be making it myself out of sheet metal. If I can work it out right, I may try to sell them in the future :-). A pipe dream I'm sure, but you gotta dream right?
And I assume OBS, but not sure. It was in clays OBS section, but I should check the SD section as well.
And yeah, I'm wishing I hadnt bought the AF fuel pressure sender, but when I was troubleshooting my power loss problem that was my next thing to check... So now that I have it, I may as well use it.
As for my thinking on the HPOP guage, yes, the AF does monitor it, but I thought it would have good 'entertainment value' as a needle gauge - I.e. It moves a lot. A dumb reason I know, but that's how I think! And same goes for turbo. I'd rather watch a needle than numbers. I figure if run the AF on fuel pressure and engine oil temp, then watch the other ones (mostly egt) on the dial gauges.
As for coolant temp, I find that despite the lack of labels the stock one works fine for me. Engine oil temp is useful in winter around here though. Pretty much the same thing as coolant temp anyway, though faster reacting.
So, I still haven't decided on that third guage, but I've started shopping around other places to maybe save a few bucks. Anyone used/know about Isspro EV gauges (not ev2).
I guess theyre an old version on the ev2 series, but thorobred diesel has them for like half the price of most other guages.
I believe Ive heard that glowsshift guages are junk. Is that right? Or am I misremembering? Any other brands to stay away from?
no progress on the console - i've been putting off the $400-500 purchase of gauges as i continue to spend money on the rest of the truck rebuild.
the plan now is to get the truck running and on the road, but with only a dash on the interior. from that point, i'll start messing with all the "extra" electrical stuff. i guess i'll hook up the pyro and scanguage for safety/troubleshooting sake, but the console, air system, radio, amp, etc. will all come secondary to a running and driving truck. :-)
