How to bleed air suspension?
I'm trying to replace the air suspension with strutmasters coil springs. Their instructions say to bleed the air suspension; the Hanes Manual says to "depress the red plastic retaining ring and disconnect the air line from the solenoid valve." I found the red-ring on the top side of each airbag next to the electrical connection. How do I "depress it" ... or more to the point, How do I get that blasted airline off?
I'll call strutmasters in the morning to see if they have any tips.
Mark
Mark
I cut...
I ended up cutting the lines. Even after I got the bags out to where I could see and handle the lines better... a little better ... I still could not get them to come out by pressing in the retaining ring and pulling.
Maybe if I had used some penetrating oil... but not sure that would be good for the lines IF I decided to go back to air suspension. Maybe one of these days I'll fix the air suspension and give it another whirl.
I did order an Air Suspension replacement from JCWhitney to try to replace hoses and compressor with their $200 Airlift kit. But it was more than I wanted to mess with at this point ... after I got it. May keep it and try that setup WITH the coil springs which is how they say it works.
Thanks for the reply and help!
expeditionph
1997-2006 Expedition & Navigator
10-10-2013 09:39 PM
jonj238
15
07-01-2013 09:59 AM
wastingas
06-09-2013 11:25 PM
jundeleon
08-19-2005 08:01 PM
01, 1997, 2004, air, bleed, bleeder, expedition, expendition, ford, lincoln, manually, navigator, suspension, suspentiob, system
