Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Reload this Page >
Air conditioning on my new truck not impressive
Old 03-31-2004, 03:21 PM
ocdmachine
ocdmachine is offline
ocdmachine is starting off with a positive reputation.
We are having our first heat wave here in Central Texas and it's the first time I really needed my AC since I purchased the truck in Feb. Man, I have owned Ford cars before and they always had great AC, this truck sucks! I called the dealer and will bring it in next week for them to check out. It blows cool, but barely. No way it's going to cool down this BLACK interior 4-door truck. Anyone else have AC issues? Hopefully it's something they can address but I'd rather go in with some background information if anyone else has my same issue. Thanks.
Old 03-31-2004, 03:24 PM
psdwanabe's Avatar
psdwanabe
psdwanabe is offline
psdwanabe is starting off with a positive reputation.
There were quite a few complaints last summer. Try a search I'm sure you'll come up with a lot of hits.
Old 03-31-2004, 06:42 PM
FLFordOwner
FLFordOwner is offline
FLFordOwner is starting off with a positive reputation.
I'm not happy with mine either look here
https://www.ford-trucks.com/forums/s...25#post1486425
or
https://www.ford-trucks.com/forums/s...d.php?t=206976
or on this site http://flatratetech.com/6literpowers...c;f=1;t=000191
i know your talking about cooling mine takes more to cool also, ford changed thier a/c systems to something um.. cheaper is what i see
Old 03-31-2004, 08:44 PM
FLFordOwner
hmm link won't work
Old 04-01-2004, 08:53 AM
$trokin60
$trokin60 is offline
$trokin60 is starting off with a positive reputation.
I agree the 6.0 deffinatly lacks in the A/C department. My 96 F-350 would freeze you out. The 6.0 will barely cool the air on a hot day. Dealership says everything check OK. must be my imagination.
Old 04-01-2004, 01:34 PM
dftrader
dftrader is offline
dftrader is starting off with a positive reputation.
Install a valve in the heater-core supply line,because the coolant is allways circulating thru the heater.I installed a 1/2" ball valve and close it in summer time.
Old 04-01-2004, 02:16 PM
FLFordOwner
my dealer told me id void the warrenty if i did that so ill let ford fix it instead of half assing something that should of been done at the factory
Old 04-01-2004, 05:28 PM
uponyou21
uponyou21 is offline
uponyou21 is starting off with a positive reputation.
i had the same issue with mine took it in and replaced a defective o-ring which was causing a leak in the system
Old 04-02-2004, 06:03 PM
NiNjA DoC's Avatar
NiNjA DoC
NiNjA DoC is offline
NiNjA DoC is starting off with a positive reputation.
Mine works great and it gets well over 120 here
Old 04-02-2004, 07:01 PM
Lashlaroo
Lashlaroo is offline
Lashlaroo is starting off with a positive reputation.
That was my First and so far only trip into the dealership for work. No A/C. There were some wires cut when the engine was installed. Cool air came out but that was it. Now, Oh My, it will run you out of the truck after a few miles at highway speed. If you have gauges, I was told by ford Mech that you should have 250psi on the high side and 50 psi on the low side. The old systems were 150+- high and 30 on the low. the bigger the difference, the better the cooling.
Old 04-02-2004, 07:48 PM
FLFordOwner
mine will freeze you out of the truck on max a/c but i cant adjust the temp on max a/c
Old 04-02-2004, 08:47 PM
Crash687's Avatar
Crash687
Crash687 is offline
Crash687 is gaining momentum as a positive member of FTE.
what the mech. did not tell you that the new systems use R-134a and the stuff does not transfer as much heat as the older R-12 systems. The bad part is that R-134a seperates when it leaks (loses parts of the chemicals that it is composed of) and the "recharge in a can" may only work once or twice before you have to completely drain, evacuate, and recharge the system.
Old 04-02-2004, 08:48 PM
SBV45's Avatar
SBV45
SBV45 is offline
SBV45 is gaining momentum as a positive member of FTE.SBV45 is gaining momentum as a positive member of FTE.
Mine works great. I have a white truck with a gray cloth seats and gray interior. Not real flashy but here in Central Texas a black interior and black seats didn't make much sense to me.
Old 04-02-2004, 11:20 PM
Choctaw Bob's Avatar
Choctaw Bob
Choctaw Bob is offline
Choctaw Bob is starting off with a positive reputation.
Mine is ice cold in central Texas. Yours will be too!
Old 04-02-2004, 11:30 PM
Tulsa_Texan's Avatar
Tulsa_Texan
Tulsa_Texan is offline
Tulsa_Texan is starting off with a positive reputation.
Lightbulb
This may be the answer from http://www.intellidog.com/dieselmann/60bulletin.htm
2004 F-Series/Excursion Lack of A/C Cooling:
Trucks built between 12-1-03 to 1-26-04 may have strands of insulation trapped between the compressor and refrigerant line manifold. The system will need to be recovered and the the insulation removed from the joint. The tube and manifold assembly (4C3Z-19D850-CA) may be reused if it is undamaged, but the o-rings (1F1Z-19E889-AB) should be replaced. Broadcast Message 1118.
Quick Reply: Air conditioning on my new truck not impressive
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
