Sponsored by: Real Truck
Gas Mileage Problem
Old Nov 22, 1999 | 02:16 PM
Robert_1's Avatar
Robert_1
Gas Mileage Problem
I've read posts on the 2000 4x4 f250 V10 gas mileage and think the average is somewhere around 15 mpg.
I'm getting 11 if I'm lucky, and that's driving conservatively. Is there anything I should check or do to get me up to the 15/16 mpg mark? Or should I be happy with the 11??
I'm afraid there may be something off with the engine that is making me get worse gas mileage than everyone else (although it seems to be running great).
I'd appreciate anyone's thoughts.
Old Nov 23, 1999 | 10:35 AM
Ranger's Avatar
Ranger
Gas Mileage Problem
Robert,
My 2000 f250, CC, 4x4, SWB, V-10 has 3:73 gears and I get 11 to 13 for everyday driving,(fairly agressive). My best in the city is 14 avg. for one tank.15-16 on the highway, empty not towing. You didnt say how many miles on your truck, I averaged 9-10 until I hit 2000 miles I have 3000 now and my mileage seems to have stabilized. Must be broke in.
I put a K&N air filter and that seemed to get me about a mile per gallon improvement with a noticable improvement in throttle response.You might try this. Good luck, Congrats on your choice of truck.
Ranger
Old Nov 23, 1999 | 02:39 PM
bamaboy
Guest
Posts: n/a
Gas Mileage Problem
Robert,
Which year end do you have? That may make a difference. I was doing some research on gas mileage before I ordered my 2000 V10. I wanted the five speed and limited slip diff. therefore I had to get the 4.30 gears. I was concerned about the gas mileage of trucks with these gears, but a couple of guys I talked to with these gears were getting around 14-15 mpg while most of the 3.73 guys were getting around 11-13. Maybe it was a fluke, but I don't know. Guess I'll have to find out for myself
Old Nov 23, 1999 | 03:23 PM
Robert_1's Avatar
Robert_1
Gas Mileage Problem
I just hit the 2000 mile mark so maybe my mpg will start to improve now too?? Hopefully anyway.
Where did you pick up your K&N filter?? I tried to pick one up around a month ago and was told that they weren't available for the 2000 f250 and wouldn't be until after Christmas??
By the way, at a stop and in park, where does your truck idle?? My truck idles at around 800rpms. I was wondering if maybe this had something to do with the gas mileage issue.
Old Nov 23, 1999 | 07:32 PM
wawii's Avatar
wawii
Gas Mileage Problem
I've just completed 6,042 miles on my Y2K SD CC w/3.73LS and I'm at a average of 14.9/15.0.
My 68 MPH Highway (No Towing) is 16.6 MPG.
My Local is 13.6 MPG.
You can see all the tanks of fuel at: <a href="http://ic.net/~wawii/MPG">http://ic.net/~wawii/MPG</a>
Hope this helps.
Will
Old Nov 24, 1999 | 12:52 PM
ackman70's Avatar
ackman70
Gas Mileage Problem
I got a 99.5 SD V-10 Supercab 4x4 with auto and the 4.30 rear. I do 90% local driving and I usually only get 12-13 MPG. I guess it would be much better on the highway. Or maybe worse with the taller gears.
Old Nov 30, 1999 | 01:15 AM
V10 MAN's Avatar
V10 MAN
Gas Mileage Problem
Robert,
More than likley the 99 filter is the same as the 2000. All 97, 98 & 99 Ford 4.6L, 5.4L and 6.8L use the same filter. F150's on up. It should cost between $30-$45.
Old Nov 30, 1999 | 11:10 AM
fourby's Avatar
fourby
Gas Mileage Problem
Jarryd
65
Jun 12, 2013 04:51 PM
99EdeBauer
18
Feb 2, 2008 11:57 AM
lougil
Jan 18, 2008 06:46 PM
DD1684
13
Dec 6, 2007 09:07 AM
4ROTN1
Feb 20, 2004 10:28 PM
