Interior Lights and Running board lights stay on
Ahhhhh the Ford Light Issue. Have not had that yet on my 98 Expy, but we DID have it on the 98 Taurus. I'm going on the assumption that you might have figured out which door is causing the problem. If not, repeat it for each and every door.
Get a decent Silicone Lube Spray (WD-40 works OK, though I used the Prestone Spray). Open the door, give the door latch mechanism inside the door a good 3-4 second drenching. Open and Close the door about 10 times. Done!
Again, not sure about the Expy, but I know for a fact that the door-latch sensors in the taurus act up. My wife's car did the same and I pulled the interior light relay for almost a year until I tried this and it suprisingly worked. Repeat the lube every oil change and hopefully it will work for you!
-Steve
-Steve
Yep...
The ole lights on ... this is what I did to my expo. 4X4 EB..
I tried the W.D. but it only came back a few days later. I had the door apart (driver) checked every concievable culprit, no cure, I got accustom to hearing " your running board lights are on"!
Go to Advance and buy electrical CRC contact cleaner (FLAMABLE ONLY) it's better than non.
Spray your driver side good ...you will see the little plastic wheel at the latch area.. this is where you need to spray. I do all doors the same way to be certain I get the right one. The back as well.
You don't have to do anything else, go in the house and forget it...on your next trip to town go ahead and look back to check (I know you do)
I can hear you now "YAHOOOO"! You may need to do this every month or so untill... walla ! Mine acts up about every four months or so .
One light spray now does it. driver side only.
cobrah
cobrah
My neighbor has an Expedition and a few minutes ago we were outside talking about how his running board lights and interior lights stayed on. I came inside, did a search on the Expedition and found this thread.
I grabbed my can of silicone spray, got my neighbor, and we sprayed his locks. Seems it was the passenger door that was the problem.
The guys and gals of this forum are the BEST! And Thank You Ken.
PS: I told my neighbor where I found the info and I bet he signs up!
cobrah
cobrah
cecilt
1997-2006 Expedition & Navigator
12-15-2009 09:25 PM
58budman
02-12-2002 07:19 PM
