Reverse Sensor Switch problem
Hello all,
Has anyone had a problem with their reverse sensor switch on the dash turning itself off? I have a 2000 X LTD 4x4. I just had the two passenger side door lock actuators replaced and now the backup sensor switch will not stay on. I press the switch from off to on and as soon as I put it in reverse it turns itself back off. Are the lock actuators wired into the backup system? This forum has been great for info since I got my X two weeks ago. Any help would be appreciated. Thanks, Alan
Hmmm....I don't think the doorlocks have anything to do with the RSS. Someone at the dealership may just be a crossed wire or (as weird as it sounds) caused a short somewhere. I'm not sure at all, but I don't see why it would do that. Maybe there was a recall about this. If I'm not mistaken, 2000 (I think) was the first year for the RSS on Excursions, F-250s, and F-350s. Nonetheless, I think there is obviously somekind of quirk in the system somewhere.
They are designed to be ready at all times. Are you saying that when you put it in reverse the off light comes on or when you put it in reverse you have to turn it off when pulling a trailer. If I turn my switch to off and then put it in reverse it will reset and I have to turn it off again. I quess it is unclear what your situation is. Maybe it's me. Toyman
