check engine light is on :(
Old Mar 24, 2004 | 07:55 PM
MuDDoG2011's Avatar
MuDDoG2011
Angry check engine light is on :(
today check engine light went on - on my 98 x sport - what should i do??
what should i check ???
and what can it be -- help me please
Old Mar 24, 2004 | 08:23 PM
rob_engineer's Avatar
rob_engineer
I don't know if the explorers work this way but my wife's mitsubishi diamante did the same thing last week. I was a bit suspicious since it happened almost exactly at 30,000 miles. Everything was running perfectly fine. I had changed the oil and flushed the transmission about two months ago. Anyway, I disconnected the battery for 15 minutes then reconnected. The light went out and has not come back on. I think it was just a preset factory prompt wanting me to send it in for routine maintenance. Disconnecting the battery reset the computer.
Old Mar 24, 2004 | 08:52 PM
maa139's Avatar
maa139
If resetting the computer doesn't work, autozone will pull the codes for you for free.
