360 Intake
Old Mar 24, 2004 | 10:53 AM
fordnut86's Avatar
fordnut86
360 Intake
Are there any intakes for a 360 besides E-brock?
Old Mar 24, 2004 | 11:08 AM
BB's Avatar
BB
Any intake for the 390 will work on the 360 (I don't know if that answered your question).
Old Mar 24, 2004 | 02:18 PM
fordnut86's Avatar
fordnut86
Well kinda, I already knew that the intakes & heads could be swapped between the two. Im asking about different companies.
Old Mar 24, 2004 | 04:10 PM
seventysixer's Avatar
seventysixer
Weiand and some older stuff from Offy I think. Lots of different stock 4 bbl manifolds. JEGs has Weiand manifolds.
Old Mar 24, 2004 | 05:05 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Well,,,,
Like with everything else in your build! Ya have to figure out what it is your going to ask the motor to do?
And then when you have that figured out!!
you can start buying part to fit that application!!
Good Luck!!! Russ!!
Old Mar 24, 2004 | 09:25 PM
seventysixer
I decided to go with a stock 4 barrel manifold. Everyone here said that the stock manifolds were just as good as an Edelbrock performer, just heavier. Stock manifolds go for about $25 and another $100 for a rebuilt carb. Leaves me the money for a set of rebuilt heads. I get where I wanted to go for less money.
Old Mar 25, 2004 | 04:51 PM
FERacing66's Avatar
FERacing66
seventy sixer, where did you get the stock 4 barrel for $25?
Old Mar 25, 2004 | 08:44 PM
rusty70f100's Avatar
rusty70f100
You might try your friendly local junkyard.
Old Mar 26, 2004 | 08:06 AM
seventysixer
I actually got an offer of two, one from a friend of a friend and one from a not so local guy on-line through e-mailing about FE engines. Networking is everything is what I am finding out. We are all over but you just don't know. Probably walking by people in Walmart that have the pieces you need in their garage. LOL
The problem with intakes is that they weigh like 75 pounds and are expensive to mail, so a local dealer, either a junkyard or private seller is the best way to go.
Old Mar 26, 2004 | 08:19 AM
fordnut86's Avatar
fordnut86
Will a holley or demon carb bolt up to a stock 4 barrel?
Old Mar 26, 2004 | 12:30 PM
76supercab2's Avatar
76supercab2
Should. I have a holley stock, original equipment from the Ford gods themselves. My dad also had one with a holley on it. And my Ford service manuals have a chapter on rebuilding holleys.
Old Mar 26, 2004 | 01:25 PM
seventysixer
I plan on using a stock Autolite 4 barrel so I don't know. You also have to be aware that there are several different stock manifolds from like '59 to '72 (guessing on 4 barrel models). There were some different holes in the older manifolds for oil filler and a downdraft tube on the pre-PCV cars.
Old Mar 26, 2004 | 02:25 PM
fordnut86's Avatar
fordnut86
The truck im about to get is a 75 so will an intake off of a 70 or so fit? Ive seen in a few catalogs FEs only going up to 72ish.
Old Mar 26, 2004 | 03:16 PM
seventysixer
Cars only had FEs until '72, that is hwere they are getting thir numbers. Trucks went until '76 with FEs. You should be good to go, mine is a '76 with a stock 360. The stock manifold and carb setup is my future. I've been told by more than one person that I should have no problems other than "might as wells" (might as well replace the timing chain, lifters, cam, oil pump......).
steve340
May 29, 2016 07:53 PM
Austy
Sep 2, 2013 01:04 PM
704core
May 7, 2007 03:27 AM
TXDod65
Jan 27, 2005 09:16 AM
