Code 24
Old Mar 23, 2004 | 07:42 PM
Rubbersoul's Avatar
Rubbersoul
Code 24
Hi everyone
89 E150 4.9L
KOEO.....I get a code 24, my code book says "Intake Air Charge Temperature (ACT,IAT) sensor or Vane Air Temperature (VAT) sensor out of range.
Is this the Air Bypass Valve on top of the throttle Body ?
Another thing....between the tank and the high pressure pump is a round black cannister.....is there a filter in it ?
tyvm
John
Old Mar 24, 2004 | 12:29 AM
EPNCSU2006's Avatar
EPNCSU2006
No. There is an air temp sensor in the intake manifold (I can't tell you exactly where - I'm not too familiar with the I6's). I think there is a small screen in the black canister, yes. There is an o-ring in there that will probably need replacing when you take it apart.
Old Mar 24, 2004 | 02:52 AM
Ford_Six's Avatar
Ford_Six
The intake air temp sensor is in the number one runner, but you have to remove the heater hose that runs between the upper and lower intake to get it out. If it's stock, a 7/8" deep socket on a swivel will get it out. Some aftermarket ones are a different size.
Old Mar 24, 2004 | 10:11 AM
Rubbersoul's Avatar
Rubbersoul
Thx alot guys I'll check it out.
Rico47635
Mar 5, 2011 10:59 AM
john19999
Nov 21, 2010 08:26 AM
john_navarro
Escape & Escape Hybrid
Jul 9, 2006 07:15 PM
randomchance
24
Oct 12, 2005 08:50 PM
