My truck has a small miss at 1200rpm with no check engine light coming on. When it is cold it is really noticable, as it warms up to normal it gets better, but always runs a little rough at 1200-1500.
Any help with this would be greatly appreciated, getting 12 miles to gallon at best loaded or unloaded.
Have hypertech tuner, afraid to install it.
Check the wiring harnesses going into the valve covers first for burnt or melted pins. Could also be the UVC harnesses inside the valve covers. I see both melt sometimes. Pretty easy fix, just have to narrow it down to shich one is bad.
The wiring goes to the injectors and glow plugs. Not sure exactly why they melt but I see it in all years. It can cause misfires, glow plug problems, etc.
