brake problems with 1999 or 2000 trucks - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-09-2000, 10:58 PM
robsfall
robsfall is offline
robsfall is starting off with a positive reputation.
i need to know how many people have had problems with brakes on 99 or 2000 f-250,350 or 450 and if your still having problems
Old 08-11-2000, 07:53 AM
ronzx9
ronzx9 is offline
ronzx9 is starting off with a positive reputation.
I have had problems with my 99 F250 SD 4X4 V10 Extended Cab. Multiple returns for brake pulse. I also have a hard time stopping the truck if there is any water on the road. I have to stand on the brakes to get her to stop and I weigh 220. Dealer thinks I'm nuts. Says nothing wrong.
Other Problems @ 20,000 miles:
CD does not eject CD's New CD player on order.
AC does not cool down. New compresser on order.
All four doors rusting on the bottoms and sills below the windows. Ford is being a pain in the but on this. No resolution yet.
Poor mileage. 11.5-12MPG at 65-70MPH.
Clunk in drivetrain when shifting to/from reverse.
Dealer can't seem to hear it.
RonZX9.
Old 08-11-2000, 05:45 PM
SuperPleased
SuperPleased is offline
SuperPleased is starting off with a positive reputation.
Yes, as a matter of fact, the rotors (front) on my '99 SD SC V-10 Lariat had annoyed me for about eight weeks with pulsing, before I had them replaced by the dealer (at no charge) . The **new, IMPROVED** rotors only lasted for about 3,000 miles before they, too, were pulsing. Problem was (and IS) that the truck was out-of-warranty by the time the replacements failed, so I couldn't expect another free replacement.
I'm a former race driver (stock cars) who learned early on to save his brakes, so you could rightfully say that I'm easy on my brakes. The Super Duty has over 41,000 miles on it as I write this, yet the brake pads are in great shape with lots of wear remaining on them.
When my dealer did the in-warranty rotor replacement for me, it was obvious from the long list of materials consumed that this brake job wasn't anything new to Ford; they'd obviously had to change out many of them on the SD's by the time they got to mine!
The replacements lasted far less mileage than the original rotors, which was a major disappointment. I'm now searching for an aftermarket rotor that has the heat warping problem under control. Ford needs to try harder on this problem!
Tom
Old 08-24-2000, 04:16 PM
jmmk
jmmk is offline
jmmk is starting off with a positive reputation.
Buy the cheapest brakes you can find , the factory brakes pads are rock hard.They put to much heat in the rotors thus warping,you might put them on more often but no pulsing.
Old 08-26-2000, 05:10 PM
loganhauler
loganhauler is offline
loganhauler is starting off with a positive reputation.
I have had the same problems with my 99 SD/Powerstroke. It has been back to the selling dealer twice for vibration when I apply the breaks. They replaced the rear rotors and pads twice and turned the front rotors (on the truck) twice and replaced the front pads twice. The truck has 58k miles on it and I had to have the front rotors turned AGAIN and replaced the front pads AGAIN. Hope I am done with this problem but the odds are against me. If anyone has a solution (other than trading the truck for a Dodge) I would like to know about it.
Old 08-27-2000, 10:27 PM
jurtu
jurtu is offline
jurtu is starting off with a positive reputation.
Could it be that the swept area is just not big enough? These are heavy trucks 5000lbs +, unloaded. American vehicles are notoriously underbraked, specialy pick-up trucks. Did your dearler intimate to you wether Ford is considering upgrading to bigger brakes in the future. Probabley not. They just don't care. They're selling Super-Duties faster than thay can make them.
Old 08-27-2000, 10:37 PM
jurtu
jurtu is offline
That gas milage is not that bad. You've got a V10, it's a 4X4, probably a 4:11 rear-end, it's pushing 6000lbs sitting at the curb, and is about as aerodynamic as a brick. I would'nt expect miracles.
I had an 84 Chevy 3/4 ton, standard cab, 2WD, long bed, 4:11 rear-end with a 350 V8 that only got about 9MPG and less towing my ski boat.
You've got a lot more truck with a lot more power and better gas milage to boot.
Old 08-30-2000, 08:19 AM
goliath
goliath is offline
goliath is starting off with a positive reputation.
The problem that I have experienced is while trying to stop a little faster than someone would normally the brakes seem to fade with a pulsating feeling (and it's not abs) especially if there is an un-even road that seems to amplify it.
Old 09-03-2000, 12:53 PM
papaharp
papaharp is offline
papaharp is starting off with a positive reputation.
I have had problems with my F-350 4X4 Crew cab Dully. When I had about 26,000 miles on it I was having recall work done on the gas tank and was talking to service rep. about how the front end would jump up and down when braking. The Rep. said that the rotors were out of round and they would turn them under warranty. When I picked up the truck two days later I was told that they also had to replace the left front hub because the four wheel drive was not disingaging all the way and was causing a clicking noise. I was told that all four rotors had to be turned and all of the brake pads had to be sanded smooth to stop the pulsing. The dealer rep. told me that I would have to look forward to turning or replacing the rotors and pads about ever 25,000 mile. He said it just a problem with the Ford F-350's. I still have a clicking noise in the left front hub but the dealer said the mechinic could not find anything wrong with and he could not hear anything. I now have 53,000 on the truck and I am having to replace the rotors and pads again to stop the pulsing. Dealer Rep. said he new nothing about any recall or anything Ford was doing to solve the problems with the rotors.
Old 09-03-2000, 11:48 PM
liltoot
liltoot is offline
liltoot is starting off with a positive reputation.
Old 05-12-2012, 07:45 PM
qwert9000000
qwert9000000 is offline
qwert9000000 is starting off with a positive reputation.
in March of 1998 they changed the rotors used on the 1999 F-450. you CANNOT mix parts between the two brake versions.
Old 07-06-2012, 04:53 AM
Indyducks
Indyducks is offline
Indyducks is starting off with a positive reputation.
I've had the same pulsing problem with my 2000 F250. The brakes are my biggest problem with this truck. I've decided to just put some kind of custom brake package on the thing. All 4 wheels. Does anyone have some suggestions? At this point, I will spare no expense in making this problem go away forever.
Old 07-06-2012, 07:53 AM
ken kenmnedy's Avatar
ken kenmnedy
ken kenmnedy is offline
ken kenmnedy is gaining momentum as a positive member of FTE.
after two sets of front rotors i gave up on factory style and went to e bay and got plated,drilled and slotted rotors with ceramic pads...255$$ 4 rotors and pads...oh my dose this thing stop...its a plow truck so they get a beating and still work great they still work great so far
Old 07-06-2012, 08:27 AM
Indyducks
Ken - What brand? I absolutely need better brakes on mine.
Old 07-06-2012, 08:52 AM
ken kenmnedy
cardone i think first ones i could find on e bay that were drilled,sloted and plate ed reaiiy just wanted to try the drilled and slot to releave the heat thing the better stoping was extra i didnt count on I went cheap beause this is my test tired of buying rotors to have them warp in 6 mounths
Quick Reply: brake problems with 1999 or 2000 trucks
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
