air bag light stays on - Ford Truck Enthusiasts Forums
Old 03-20-2004, 10:33 PM
jen53010
jen53010 is offline
jen53010 is starting off with a positive reputation.
I am looking at a 2000 explorer at an auto dealership that ran out excellent, but the air bag light/indicator stays on. It was a nice vehicle except for that. So I ran a check on Carfax and it showed clean, no accidents or airbag deployment, etc. Should I be worried that it had been in an accident and it doesn't show?
Old 03-20-2004, 10:39 PM
JerNla
JerNla is offline
JerNla is starting off with a positive reputation.
Bring it by Auto Zone or Advance Auto they will pull the codes for free. Or bring it by a Ford Dealership and ask them.
Old 03-22-2004, 03:48 PM
oshoguno's Avatar
oshoguno
oshoguno is offline
oshoguno is starting off with a positive reputation.
Does your air bag light flash a code on startup? It should flash a number of times, pause, flash another number, longer pause and repeat two more times. All I know is that a 36 or 37 is a seat sensor. Under either front seat is a small electrical plug that is easy to be hit by anyone in the backseat. Look for an unplugged plug or a broken wire. Hope that helps.
Old 03-27-2004, 12:32 PM
jen53010
jen53010 is offline
airbag light stays on in explorer
Thanks, it flashes on and off and then stays on during driving. There is no code that I see.
Old 03-27-2004, 07:24 PM
oshoguno's Avatar
oshoguno
oshoguno is offline
Count the flashes. When you start the vehicle count the flashes till you get a pause (that's the first number), count the number of flashes till you get another pause (that's the second number), It should repeat that sequence twice more. Let me know.
Old 03-30-2004, 09:10 AM
Vito in TN's Avatar
Vito in TN
Vito in TN is offline
Vito in TN is starting off with a positive reputation.
Question Re: Air Bag light stays on
[FONT=Comic Sans MS]My airbag light flashes code 32 on occasion. What does that code mean?
Old 03-30-2004, 09:32 AM
oshoguno's Avatar
oshoguno
oshoguno is offline
I found this in another Enthusiats forum. The link is https://www.ford-trucks.com/forums/a...x.php/t-169332
This is the airbag code list for a 96 Explorer:
AIR BAG DIAGNOSTIC MONITOR DIAGNOSTIC TROUBLE CODE (DTC) PRIORITY TABLE
DTC.......LFC......Description.................... ..................Action To Take
B1342....24........Internal microprocessor fault..............GO to Pinpoint Test A.
...................................(retrieved only during on-demand self test)
B1867...12/52....Lost battery feed or low battery..............GO to Pinpoint Test B1867.
...................................feed voltage
B1869.......- .....No air bag indicator - Inoperative.........O to Pinpoint Test C.
...................................indicator circuit
B1913......13/53.........Air bag driver/passenger circuit...................GO to Pinpoint Test B1913.
...................................short to ground
B1914......14/54.........Primary crash sensor circuit shorted...................GO to Pinpoint Test B1914.
...................................to ground
B1921.........21...........Air bag diagnostic monitor ground...................GO to Pinpoint Test B1921.
...................................circuit open or not mounted to vehicle properly
B1922.........22...........Safing sensor output circuit shorted...................GO to Pinpoint Test B1922.
...................................to battery voltage
B1923.........23...........Memory clear circuit improperly...................GO to Pinpoint Test B1923.
...................................grounded
B1924.........24...........System disarm failure or internal...................GO to Pinpoint Test A.
...................................diagnostic monitor fault
B1932.........32...........Driver side air bag high resistance...................GO to Pinpoint Test B1932.
...................................or open
B1933.........33...........Passenger side air bag circuit high...................GO to Pinpoint Test B1933.
...................................resistance or open
B1934.........34...........Driver side air bag circuit low...................GO to Pinpoint Test B1934.
...................................resistance or shorted
B1935.........35...........Passenger side air bag circuit low...................GO to Pinpoint Test B1935.
B1941.........41...........RH primary crash sensor feed/return...................GO to Pinpoint Test B1941.
B1942.........42...........LH primary crash sensor feed/return...................GO to Pinpoint Test B1942.
B1944.........44...........RH primary crash sensor not mounted...................GO to Pinpoint Test B1944.
...................................to vehicle properly or ground circuit open
B1945.........45...........LH primary crash sensor not mounted...................GO to Pinpoint Test B1945.
DTC - Diagnostic trouble code, retrieved using New Generation Star (NGS) Tester 007-00500 or equivalent.
LFC - Lamp fault code, flashed on air bag indicator.
I hope this helps.
gpauge
Ranger & B-Series
05-11-2017 05:45 PM
pablocruz69
Ranger & B-Series
21
10-25-2016 09:11 AM
007ROADSTER
Ranger & B-Series
15
02-01-2016 05:37 PM
miuwcm3
04-10-2014 01:16 PM
sadyedog1
1999 to 2016 Super Duty
07-11-2011 06:29 AM
Quick Reply: air bag light stays on
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
