Minnesota Chapter Join Chapter, Leader: fordpower88
Carb work on a 300 - 6cyl, local
Old 02-24-2004, 03:01 PM
Jimmn's Avatar
Jimmn
Jimmn is offline
I have a '81 F-100 with a 300 IN6, 76,000 miles which I bought from my dad. Runs, but not great, boggs down and sputters when I accelorate hard. Everyone I talk to points to the carb, (carter 1bl) More than I wish to tackle with my knowledge and tools. I have called around, but nobody seems to want to look at or work on a carb engine. Can anyone suggest a mechanic in the NW suburbs of Mpls?
Old 02-24-2004, 03:46 PM
Ford79's Avatar
Ford79
Ford79 is offline
It would be best to have the carb rebuilt. See if you can get a rebuild kit from an auto parts store and I may be able to rebuild it for you.
Old 02-24-2004, 08:12 PM
Boss_358's Avatar
Boss_358
Boss_358 is offline
Rebuild kits are pretty easy to find for those carter carbs. But they have a common problem that can lead to severe frustration from time to time. There are I believe 4 screws that hold the two bottom halves of the carburator together. They are known for comming loose and causing vacuum leaks. Sometimes solving problems are as easy as tightening those screws.
Old 03-24-2004, 07:37 PM
innecity4wheelin's Avatar
innecity4wheelin
innecity4wheelin is offline
try sundemn carbs in minneapolis, think my old man said thats the guy to talk. , well anyways he trusts him. but i rebuild my own so i wouldnt know.
rbtom
01-03-2015 12:18 AM
Grot
02-01-2011 08:50 PM
F250DUDE66
05-19-2009 01:09 PM
Rosie
04-19-2006 01:46 AM
MEPR
03-18-2003 06:03 PM
Quick Reply: Carb work on a 300 - 6cyl, local
