Base Timing on a 2.3L ?
Old 04-10-2004, 02:59 PM
coplin's Avatar
coplin
coplin is offline
anyone online right now?
Old 04-10-2004, 03:07 PM
King Triton's Avatar
King Triton
King Triton is offline
That little dot next to your name,when it turns to green,it means they are online,
Whats up?
Old 04-10-2004, 03:10 PM
coplin's Avatar
coplin
coplin is offline
hey there how do you set base timing on a 2.3 liter ford?
Old 04-10-2004, 03:23 PM
King Triton
Yes there is a little gray plug close to your distributor,unplug it,then set your timing to 10deg before tdc.If you need me to go into greater detail just shout.
Old 04-10-2004, 03:30 PM
coplin's Avatar
coplin
coplin is offline
yes aliitle more detail please, I know about the spout but where do you physically set the accesory shaft/sprocket when doing timing belt change out to get the initial base timing set after that the computer does the rest??.
Also have some codes for you
223:dual plug inhibit_ what's this mean?
224:IDM input?
Thanks
Old 04-10-2004, 03:36 PM
King Triton
Well,ya got to give me a little more to go on,first what year is it,second are you asking me where to set the crank and cam alignment marks,
Old 04-10-2004, 03:40 PM
coplin's Avatar
coplin
coplin is offline
its a 92 no dist.and its the 3rd shaft i need to know how to set.there is a mark on the pulley but nothing to reference it to
Old 04-10-2004, 04:32 PM
King Triton
ok,first the aux shaft does not need to be timed,and your IDM is Ignition diag monitor, and both of those codes could be related to your crank sensor,which leads me to more questions,did it the old belt break,is this a no start?And sorry it took so long to get back to ya,I have kids and get(but dad i need it for homework).
Old 04-10-2004, 05:07 PM
coplin's Avatar
coplin
coplin is offline
no breaks, but belt is worn out. it does start but is rough.the only info i could find seemed to indicate primary ign so maybe it is related to the crank sensor. thanx for all the input tho.
PS i know how the parenting thing goes myself!
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Base Timing on a 2.3L ?
