D rated tires OK for PSDs?
I have been reading the threads on the different tire brands and sizes. All the larger tires (larger than 265s) seem to be D rated and not the E rated tires that came on the truck. I have the 265s now, but want to move up to a 285 or 295 size that all seem to be D rated.
Will these tires be ok on a 7.3 PSD, considering the weight? I know most guys run these, I am just interested if there is any decrease in safety. Thanks.
The E rated tires have a higher load capacity than the D. If you don't tow much, or haul much weight in the bed, then you'll probably be fine with the D rated tires. I've been thinking the same thing since we're taking all of these perfectly good Steeltex tires off of the Expeditions, I may keep a set to put on when my BFG's wear out.
Like everything else it all depend on the tire maker. It can even differ within a manufacturer. I have a set of 35x12.5r16.5 BFG A/T, D rated 50psi max cold (3415lb/each). BFG has some other sizes (still A/T, still D rated) which they recommend 65 psi. So what I am saying is you are probably both right.
Mike
Mike
