77 High Boy Front Axle Swap
I have a 77 High Boy with the stock low pinion D44 front Differential. Has anyone seen a writeup of Front high pinion D44 or D60 Differentails that that will drop in to a 77 High Boy?
Thanks,
Dave
http://www.superford.org/registry/ve...=15420#content
Thanks,
Dave
i threw a high pinion d60 under the front of my truck. can we say simple? just hack up the truck, disconnect the brake lines, driveshaft, and the draglink. unbolt the u-bolts, let the old axle drop out. just repeat this in reverse for putting the 60 back in. i wouldnt go with a 44 if your going to make the effort to do a swap. just spend the extra money and get the 60, you'll be happier in the long run.
The Freak
05-14-2015 08:56 AM
72crew
05-11-2000 10:31 AM
