1956 Custom Cab front windshield Chrome
Old 03-12-2004, 10:36 PM
poolpro51's Avatar
poolpro51
poolpro51 is offline
Angry 1956 Custom Cab front windshield Chrome
I'm trying to install the chrome trim that fits around the windshield. Do I have to remove the windshield to do that. If not how is it installed?
Mike
Old 03-13-2004, 04:31 AM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is offline
The windshield needs to be removed. You will also have to buy a new seal that has the GROVE in it for the chrome. Then install the new rubber onto the windshield and then install the chrome in the grove in the rubber and then install the entire assembly. If you have never done this before, you'll be in need of some assistance.
These are a pain to install with the chrome trim.
Kevin
Old 03-14-2004, 01:14 PM
poolpro51's Avatar
poolpro51
This is what I did not wanna hear. I have the seal, but the windshield is installed. So back to square ONE.
Thanks for your help.
Mike
Old 03-14-2004, 11:17 PM
Glackowitz's Avatar
Glackowitz
Glackowitz is offline
Bigwin,
Thanks for the info...as I have one of them big back windows too and the front and back both have the trim....gotta love it
Poolpro..Good luck on that chrome
Glack
Old 05-28-2015, 12:56 AM
edsf100's Avatar
edsf100
edsf100 is offline
Any tricks doing this? Does the trim stay in without falling out of the groove. I'm getting ready to do this. Any advice will help.
Old 05-28-2015, 05:29 AM
towd56's Avatar
towd56
towd56 is offline
I just did this. As stated - rubber then trim while glass is out. I had someone on the inside of truck and made sure everything was centered before removing the rope from the inside of cab. I started in center and worked to pass side then drivers side - pulling the rope slowly while pressure was placed on outside of glass. Go slow and it will be fine
Old 05-28-2015, 11:39 AM
CharlieLed's Avatar
CharlieLed
CharlieLed is online now
The way the stainless steel trim is shaped makes it impossible to install in the rubber seal without bending the seal back to slide in the trim. With the glass in place the rubber seal is fixed and will not bend as needed to make the installation of the trim possible.
vidaliaman
05-17-2016 04:30 AM
ncbassr
38
02-18-2016 12:56 AM
67 StylesLide
15
08-12-2015 09:33 AM
jimmyjack
06-13-2009 12:40 AM
texcan
11-21-2006 06:44 PM
Quick Reply: 1956 Custom Cab front windshield Chrome
