engine
Old Mar 12, 2004 | 08:21 PM
ford390gashog's Avatar
ford390gashog
engine
my 75 ford f 150 390 won't start it has spaerk and gas but will not light the gas is new could someone help me
Old Mar 12, 2004 | 08:26 PM
kermit's Avatar
kermit
is this a new problem, has the truck sat for a while without being started, or is it a daily driver that just isnt starting??
Old Mar 12, 2004 | 08:47 PM
ford390gashog
this is a new problem the truck was just redone i am trying to start it for the fist time since i started redoing the truck
Old Mar 12, 2004 | 08:57 PM
GoldenDually's Avatar
GoldenDually
Just a thought. Distributor 180 out? Good Luck
Old Mar 12, 2004 | 11:26 PM
kermit's Avatar
kermit
one in a million shot, but i had it work on a 302 i rebuilt....try taking a dishsoap bottle and shooting a shot of engine oil down each cylinder through the spark plug hole...builds up the compression until the engine oiling system can kick in. if you have been trying to get it started, and gas is going in the cylinders but not firing, it could have washed down the cylinder walls and you could have lost compression. just a thought though.
Old Mar 12, 2004 | 11:52 PM
ivanribic's Avatar
ivanribic
I'm with GoldenDually on this one. If you've got spark and fuel is right then check your timing. I had the exact same situation with my truck when I put in a new ignition, distributor was off 180. I flipped it around and it fired right up.
Old Mar 13, 2004 | 07:52 AM
F150daniel's Avatar
F150daniel
i've have the timing chain jump when i shut off the engine and it wouldn't start.
you said you just got done "redoing the truck" did that include the engine?
Old Mar 13, 2004 | 08:30 AM
brownt's Avatar
brownt
Ivan,
How do you tell if the distributor is out 180 degrees? I am having trouble starting too.
I thought it might be out because the vacuum send is facing the rad...not the engine, thought maybe it should be facing the engine. My vacuum hose curls around and heads back to the engine.
ford390gashog
Aug 25, 2004 07:21 PM
ford390gashog
Jun 8, 2004 09:48 PM
ford390gashog
May 22, 2004 06:58 PM
ford390gashog
49
Apr 8, 2004 08:07 AM
proeliator
Dec 29, 2002 04:59 PM
