are these performance upgrades a good idea
i have an 03 f150 with a 4.6, here are all the modifications i want to do, is it a good idea to do all these?
open air filter intake
2.5 in. dual exhaust with no mufflers
shorty headers
underdrive pullies
75mm throttle body
80mm mass air meter
custom burnt chip or programmer
shorty headers
underdrive pullies
75mm throttle body
80mm mass air meter
I would skip on the throttle body, bigger throttle body's have been shown to loss 4-6hp on a dyno, they do add slightly better throttle response, but not worth lossing power and waisting money, that's the first thing I bought was a 70mm throttle body. I would increase the MAF, might want to look for MAF off of a Navagator, they are 80mm are since they are a stock ford piece they will be dead on, unlike some aftermarket ones, like others have said, your chip will have to be burnt for the MAF and they will have to be added at the same time. The big two power adders are the chip and pullies.
on
Chips contain several tables for air and fuel ratios. The MAF sends a voltage reading to the computer based on the air-flow. Switching to an aftermarket MAF or a larger MAF will usually result in an incorrect voltage reading for a given airflow. The end result is the vehicle will run too lean in parts or all of the RPM range.
NCFarmLife
03-01-2017 10:48 AM
hosscat76
20
10-07-2014 04:11 PM
Crewcabber
1983 - 2012 Ranger & B-Series
07-06-2014 06:32 PM
