if it wont send fire to the coil...
1987 F150 big6cyl, FI 4.9
update...We found that our neutral safety switch (located on clutch pedal) has lost the 1/2 clip that activated the plastic switch contact when pedal was depressed...thus not disenguaging the kill switch at all.
We had to really contort to see the area where the plastic rod and clip were located, even with the fuse pannell removed. Hope this helps someone else!!
Truck now runs, needs muffeler bad, cut off at exaust manifold pipe curves, but hey! It starts!
Thanks all!!!!!
Thanks all!!!!!
LARIAT 85
06-01-2010 05:52 PM
brodriguez
02-21-2008 08:42 AM
vincent714028
11-27-2006 08:43 PM
Tanner5
11-25-2004 12:55 PM
