problem w/ 4.2
Old 03-05-2004, 02:23 PM
Chesterx's Avatar
Chesterx
Chesterx is offline
97 F150 standard cab 5 speed manual
116500 miles
Underpowered....
Coolant loss, overheated ---> New front cover gasket at 42,000 miles...
Ran fine until...
Noticed a slight knocking when changing gears last week, checked coolant, it was low. Added water and saw an oily sheen appear. While driving to get oil for an oil change (too late!) it started knocking like crazy!
So now its rebuild time...
Old 03-05-2004, 02:26 PM
Busa01's Avatar
Busa01
Busa01 is offline
www.leakingfords.com
This website will explain your problem in detail, as well as point you in the right direction for complaint filings with Ford and government agencies.
Tom
Old 03-05-2004, 03:17 PM
true4.2's Avatar
true4.2
true4.2 is offline
yup
and no, our 4.2's are definately NOT underpowered.
Old 03-05-2004, 09:42 PM
Chesterx's Avatar
Chesterx
Chesterx is offline
Whoops, my mistake. I ment to post this under Stampede's post about problems with the engine....
Good news is I found someone to rebuild it that's within my budget...it goes in the shop on monday...
Old 03-05-2004, 10:04 PM
BrianA's Avatar
BrianA
BrianA is offline
No problem! Glad you found somebody to help you out with your rebuild. Keep us posted.
