belt tensioner question
Old Mar 3, 2004 | 06:29 PM
Rick78's Avatar
Rick78
Started a tune up on my 92 f350 Crewcab/460 c.i. So far have replaced the air filter and pvc filter, also the serpentine(spelling?) belt that runs the power steering and a.c. pump. I noticed that the tensioner pulley was somewhat grooved and tended to rattle a little when I spun it, although the bearing felt fine. Should I replace it, and if so, how difficult is it to do? Can it be done w/out removing the entire assembly from the block? Didn't get any farther because it's still cold up here and my fingers had had enough.
Regards, Rick
Old Mar 3, 2004 | 08:34 PM
RTM's Avatar
RTM
Mine on my 351W sounded the same way so I went ahead and changed it. I feel any time you can hear the bearing can't be good.
As for swapping the old part out for the new. It was a piece of cake on my 351W. I have never changed one on a 460 before.
Old Mar 11, 2004 | 09:47 PM
xltlariat87's Avatar
xltlariat87
should be just a bolt in the center of the pulley. take the bolt out change pulley. should be up & running
Old Mar 11, 2004 | 11:15 PM
c96drumm's Avatar
c96drumm
If it's like my 302, it has left hand threads...
Old Mar 13, 2004 | 01:04 AM
Rick78's Avatar
Rick78
Thanks,all. I just replaced it. Old one had seen better days. Just one left-hand threaded bolt and we were back in business!
Regards, Rick
