Window size on 56-passenger door
Since my "new" truck is missing the passenger side door (main) window , i need to make a temporarly window cut out in lexan in order to drive it home when it arrives on monday.
Does anyone have the exact measurement of this window?
Maybe even a pic or a drawing with measures.
this would help lots to keep me from freezing when picking up this truck!!
Sorry, no help on exact measurements, but.......
Here's what I'd do:
Bring along a good size piece of cardboard, some clear packing tape, something to cut/trim the cardboard to fit the opening, and some kind of clear plastic (plastic pane ~ 16" X 20"). Cut the cardboard so it fits the door curvature, then cut an opening in the cardboard and "frame" the plastic/clear piece inside the cardboard. Use the clear packing tape on both sides of the cardboard to secure the clear piece inside the cardboard cut-out. Hopefully, this'll get you home and provide SOME sort of protection against the frigid Nordic winter air!
I know it sounds kinda "makeshift", but if all else fails and no one chimes in with the '56 measurements you need.... what the heck, this may be a good enough solution for the short term. Oh, just another $.02 worth: maybe try to pick the truck up during the day if it's warmer in the day vs. the night this time of year in Norway!
Good luck!
Here's what I'd do:
Good luck!
yeah i thought that something like this could work, only that i was thinking of wrapping the upper portion of the door and tape it on the inside before closing it.
it also can be very cold in the daytime so i want the window opening closed as tight as possible. thanks lots for the tip, daryl.
vrongpeis-
I think you are worrying for nothing. Since your truck is coming from California to Norway I think it will refuse to start, you will probably end up having it towed on a flat bed and you will be in the nice warm cab of the tow truck. Just kidding, of course. I measured my 56 window opening: 17" wide x 15 3/8" high. The glass would be a little larger but maybe this will help. Good luck.
Larry
Larry
hello to you helge , congrats with the truck and welcome to FTE.
what i did for books about the F-100 was to order books from BOOKS4CARS.COM , it`s a shop in seattle with new and used books in all shapes and kinds , and it ship`s fast too. Do you have pictures for your gallery? is it an import that you brought home, or was it already in norway? i`m picking up my new truck on monday! (check gallery in left sidebar.)
I`m going to pick up the car on Wed.
The car is allready in Norway, just 6mil from my homeplace.
I`m really looking forward for my new car.
The one thing I have to order is a power steering, do you have a good place to shop for parts like this?
I will try to find some pictures during this weekend.
steering
But you have to change the steering system on the F100, don`t you?
I was about to order a powersteering kit from John`s f100, but I understand that the Servomotor not is inkluded.
I also have a half turn on the steeringwheel with no effect, so some parts must be out of order.
I am going to put the car in a garage tomorrow, ans start building it up, a lot of work
