4.2L piston firing order - Ford Truck Enthusiasts Forums
Old 02-27-2004, 08:05 PM
f150-az's Avatar
f150-az
f150-az is offline
f150-az is starting off with a positive reputation.
Hey guys, I'm looking to do a leak down test on my motor, but need to know the piston firing order. Anybody know this? And also, has anybody done this before and know the easiest way to keep track of when the pistons are top dead center and the valves are closed? Any help is appreciated guys.
Old 02-27-2004, 08:45 PM
BlueOvalFitter's Avatar
BlueOvalFitter
BlueOvalFitter is offline
BlueOvalFitter is gaining momentum as a positive member of FTE.
Firing order; 1-4-2-5-3-6
When I use to rebuild engines I would watch the rockers as the piston moved up the cylinder on the compression stroke and they would not move,and the damper indicated 0 degrees.Or,put your finger in the plug hole;as you feel the compression look at the damper and stop it as it nears 0 degrees.
Kj.keiscome
06-13-2017 09:50 PM
JorgeAlba
6.4L Power Stroke Diesel
06-13-2017 04:27 PM
Boba Fett
09-28-2010 11:27 PM
f150-az
1997 - 2003 F150
03-02-2004 11:12 AM
f100guy
3.8 & 4.2L V6
02-04-2004 11:22 AM
Quick Reply: 4.2L piston firing order
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
