Fuel pump installation woes.......
Old Feb 24, 2004 | 09:41 AM
FERacing66's Avatar
FERacing66
Unhappy Fuel pump installation woes.......
okay guys thanks for the info on the fuel pump i called autozone and found out that the filter is already in it like you guys said. i just hope they didnt forget at the facory....anyway the other day i tried to put the new pump in and what pain in the rear!!! i didnt finish it cause i couldnt get the bolt on the oppsite side of me threaded in. im going out again to try it but does anyone have any tips to make this job easier? also that arm thing that goes into the engine, i just kinda pushed it in there, is there any way i should set that arm in there? thanks again for the help.
66 F-100 352 V8
Stepside 4spd
Major peformance rebuild coming as soon as i can afford it!!!!
Old Feb 24, 2004 | 10:03 AM
78fordman's Avatar
78fordman
on my 74 390, i took off the ps pump and i could get to everything.
Old Feb 26, 2004 | 03:52 PM
bob arrington's Avatar
bob arrington
put studs in the bolt holes , makes it much easier to install,bob
Old Feb 26, 2004 | 04:59 PM
Ratsmoker's Avatar
Ratsmoker
The arm goes on top of the eccentric right guys? Been a while since I used a mechanical. You can loosely thread bolt bolts once you get the arm in the right place. Turning the engine over a bit might help also as the eccentric might be at its fullest extension right now causing the arm to have to move a good distance to make the base flush with the timing cover.
Old Feb 26, 2004 | 06:16 PM
fordaholic-67F100's Avatar
fordaholic-67F100
Ok, her you go. make sure the fuel pump eccentric is all the way up. use a screw driver or a small wooden dowel rod and stick it in the hole. when you place the rod in the hole start by pointing it down towards the oil pump and then lift up till you feel the eccentric. then rotate the crank till you fell the rod go up, stop just as you feel it start to go down. then in stall the pump. an old ford mec showed me this trick a long time ago. not to mention a few other tricks of the trade. hope this helps.
the pump drive lever goes under the eccentric.
Old Feb 26, 2004 | 09:43 PM
Ratsmoker's Avatar
Ratsmoker
You are right. It does go underneath.
Old Feb 26, 2004 | 10:46 PM
76supercab2's Avatar
76supercab2
Same thing happed to me. Bump the engine over 1/2 turn and the holes will line right up.
Old Feb 27, 2004 | 07:16 PM
fordaholic-67F100
glad I could be of help. it has been four years since I did this for ford and you guys are knocking out the cob webs. I love FTE, wish I had found this place a long time ago. keep them old trucks rollin on
Demeron
70
Oct 26, 2012 08:11 AM
johnred
Jun 14, 2011 02:37 PM
79outlawf150
Jun 3, 2010 08:49 AM
kwasham
Apr 25, 2005 03:20 PM
ADSf100
18
May 2, 2003 08:43 PM
