Adjustable Rocker Arms
Old Feb 23, 2004 | 04:34 PM
Winchester's Avatar
Winchester
I'm in need of a little help from all you veterans out there regarding FE rocker arm assemblies. I've been through Steve Christ's "Big-Block Ford Engines" several times (which is an excellent read might I add) and have come across a dillema.
On page 47 it states:
"Adjustable rocker arms are often used in hydralic-lifter engines because their higher ratio gives a slight increse in valve lift. Adjustability also makes it easier to obtain correct valve clearance or adjustment."
Then on page 141 it states:
"Rocker arms used with hydralic lifters have no adjustment provisions because they rarely need adjusting."
I'm in the process of looking for a set of adjustable rocker assemblies for my 390 but I just wanted to clear up this confliction. To me the quote from pg.141 seems to make better sense. Can anybody help me clear this up? Thanx.....
Old Feb 23, 2004 | 04:45 PM
gtex's Avatar
gtex
My take: if you're running a mild hydraulic cam, non-adjustables should be fine and will not require as much maintenance.
If you plan to run a larger cam, (I consider .550" lift a good break point) then adjustable rockers will help. Generally at this point you're running upgraded springs and retainers, so the adjustables can help with setting the preload on the lifters.
Old Feb 23, 2004 | 06:26 PM
Winchester's Avatar
Winchester
Why is it that most of the aftermarket cam manufacturers suggest that you must use adjustable valvetrain?
Old Feb 24, 2004 | 11:23 AM
Annihilator's Avatar
Annihilator
Not sure...... but I do know that when they list their lift figures that they usually do it with the 1.76:1 ratio (adj.) rockers and not the the non adjustables.
Old Feb 24, 2004 | 04:39 PM
Ratsmoker's Avatar
Ratsmoker
Because they want to sell you their rocker arms! The only time you need to run adjustables with a hydraulic cam is if the base circle of the lobe has been modified to accomodate a bigger lift. I do agree with Greg though. When you run big cams you want to be able to set your preload correctly. I know there are plenty of people out there running the Crane cams with stock non-adjustable rockers.
Just as a note, you will need adjustable rockers with the edel heads unless you have them done correctly by a machinist. The intake and exhasut valves aren't even the same height.
Old Feb 25, 2004 | 01:09 PM
Annihilator
The non-adjustable's are 1.73:1 ratio in case you were wondering. The adjustables are prefered by most for their increase in ratio (although it isn't much). As long as everything is set up correctly, I don't see anything wrong with running non-adj. as long as they are in good shape along with the shafts. When a guy gets into the bigger cams they probably aren't as good of an idea but I know a guy who ran non-adj. in a 390 with a comp. 280H cam for a while and he didn't have a problem he just went with the adjustable's later on.
Old Feb 25, 2004 | 03:53 PM
Winchester's Avatar
Winchester
Is the Crane 941 too much cam for the non-adjustables? Are the standard aluminum rocker stands tough enough as well? BTW this engine will rarely if never see 4500rpm.....
Thanx guys...
Old Feb 25, 2004 | 05:30 PM
Ratsmoker's Avatar
Ratsmoker
If you have aluminum rockers then they aren't stock and they will hold up fine. I have never heard of a rocker arm breaking in any FE engine but I'm sure it has happened in some race engines one time or another. The stock ford rockers are made of iron. The 941 is not too much cam for stock rockers IMHO.
Old Feb 25, 2004 | 06:37 PM
Winchester's Avatar
Winchester
Actually it's the aluminum Rocker Stands I was inquiring about. Sorry bout that.....
Old Feb 25, 2004 | 07:17 PM
Ratsmoker's Avatar
Ratsmoker
Yes, they are tough enough as long as they are in good shape. The 941, from what I hear on here, is not too much for the stock valvetrain to handle. I would call it the limit though.
Old Feb 25, 2004 | 07:42 PM
Winchester's Avatar
Winchester
Thanx for all the replies guys, much appreciated. I'm going to give the 941 a try with my existing valve train. Worth a shot at least....
Old Feb 25, 2004 | 08:14 PM
gtex's Avatar
gtex
You're probably OK. I ran the crower power Beast, .546" lift on stock vale train. No issues up to and a little past 5500 RPM.
Again, assuming all parts are in good shape. If some parts are near death, then you'll probably figure it with that cam real quick.
Old Feb 25, 2004 | 08:32 PM
Winchester's Avatar
Winchester
I've checked out most all of the components and so far everthing is real tight and well with-in spec. Is there any apprehention to cutting down the flow to the rockers by ways of restricting oil flow?
wagonerkl
26
Jul 25, 2011 10:03 PM
tater_51
Dec 31, 2010 06:45 AM
jstandle
Feb 8, 2005 09:40 AM
Alz Ryde
May 20, 2003 12:57 PM
marine73
Jul 28, 2002 06:42 PM
