Miles pr gallon in F-100
Old 02-23-2004, 02:01 PM
vrongpeis
vrongpeis is offline
vrongpeis is starting off with a positive reputation.
With a stock 302 w/automatic , in a stock 56 , gentle speed on highway , what kind of gas usage are we in to ?
Old 02-23-2004, 04:07 PM
Jag Red 54's Avatar
Jag Red 54
Jag Red 54 is offline
Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.
Talking
My buddy's 56 has a 351 and he gets about 15 mpg. I've heard some guys say they can do 20, but I think it depends on the rear end ratio. John
Old 02-23-2004, 05:49 PM
fatfenders's Avatar
fatfenders
fatfenders is offline
fatfenders has a good reputation on FTE.fatfenders has a good reputation on FTE.fatfenders has a good reputation on FTE.
I've went about four months on my last tank of fuel and I still got a quarter tank. I attribute it mostly to my world class tuning skills.
Old 02-23-2004, 08:50 PM
tacson's Avatar
tacson
tacson is offline
tacson has a great reputation on FTE.tacson has a great reputation on FTE.tacson has a great reputation on FTE.tacson has a great reputation on FTE.tacson has a great reputation on FTE.
I have a 1988 302 EFI with an AOD tranny with a 8" rear end with a 3.40. I get right about 21 -22 MPG in my 55'. I have a rear mounted gas tank from a 1980 Ch#$y Van and I am running 215/65R 15 tires all the way around. Hope this helps
Old 02-23-2004, 09:20 PM
fatfenders's Avatar
fatfenders
vrongpeis
Need a lot more info. Rear gear ratio? Injected or carb? Tire size? 3 Speed or OD trans? All can make a huge difference. I have driven carbureted 302s in heavy vehicles that barely got 12 MPG, 18-22 MPG might be typical for an injected 302 with an OD , conservative tires and gears. With the non-aerodynamic F100, 20 would be an achievement. Sounds like Tacson is dialed in very well.
Old 02-24-2004, 08:10 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
GreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to all
Re: Miles pr gallon in F-100
Like 'fenders sez, there are variables. I'd say you were looking at somewhere between 12 and 20 depending on those variables. If I can get 15 on my carbureted 350 with 2.20 rear gear and automatic, I'll be a happy camper. How are gas prices in Norway...$3-4 a gallon?
Old 02-24-2004, 11:57 AM
F250Rob's Avatar
F250Rob
F250Rob is offline
F250Rob is gaining momentum as a positive member of FTE.F250Rob is gaining momentum as a positive member of FTE.
Here's an example of how NOT to do it:
272 Y-block with 4 barrel carb, 3 speed no overdrive, 4:88 rear end, stock wheels and tires....the whole thing nets me about 8 mpg!!
Oh well, at least the truck sounds cool.
Old 02-24-2004, 01:09 PM
Jag Red 54's Avatar
Jag Red 54
Hey Rob, you know one of the problems with having too much power in these trucks is that the rearends loose traction because of no weight. I bet your traction as well as your trip range would increase with an auxilary 40-gallon tank mounted in the bed. John
Old 02-24-2004, 01:34 PM
vrongpeis
you guys are right , you need more info on truck for accurate measures, fact is i dont know yet , just trying to find out what to expect before i get the truck home .
the price for a gallon of gas in norway (95 oktane unleaded)
is 4-5 dollars or 8.50-9.50 NKR pr litre.(this is the cheapest oktane) add over a buck a gallon for super 98.
Old 02-24-2004, 02:23 PM
55Bubba's Avatar
55Bubba
55Bubba is offline
55Bubba is starting off with a positive reputation.
As other respondents have stated, rear end ratio and overdrive on the tranny will all seriously affect your mileage. My 2003 F150 with 5.4 l and 3:55 rear end with AOD gets about 19 on the hwy at cruising speeds and 12-14 in town. It's much more aerodynamic than the F100 and the Fuel injection should help too.
Now ..smiles per gallon is incredibly high with the F100 because it always gets smiles and finger pointing
OR
is it laughs and funny grins?
Oh well I just smile and wave back !
From the outhouse
Bubba
Old 02-24-2004, 08:07 PM
fatfenders's Avatar
fatfenders
Get your hands on an injected 302 if you possibly can. You can count on 25% better fuel mileage and often more.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
