Underheating engine
Underheating engine
I have a 1.9L engine and it isn't heating well. The problem is the engine won't get to Normal on the temperature gauge. I figured since it was an older vehicle it needed a new thermostat. I replaced it tongiht and it did the same silly thing. Any one have any suggestions on what it could be?
I can get the temp in the Normal area of the gague by sitting at a high idle (3000 RPM) and sitting for about 5 mintues. I take it out on the road and it cools back down to where the needle is below normal. I need help! It is cold in Wisconsin!!!!
I tried to replace the t-stat in my 94 2.3L truck, but I had to give up on that thought. I would get the radiator cap tested. If it doesn't hold pressure, you obviously won't get a temp increase, either.
My truck will warm up eventually, but idles crummy at cold start-up and smells a little rich. My t-stat checked out okay, btw....temp gauge works, but doesn't move muh past the left "\" mark well to the left of "NORMAL".
genscripter
07-07-2015 11:18 PM
