Storage of the hard top...
I plan on taking mine off in the summer as well, but I am limited on room. I think I will suspend mine from the garage ceiling using rope and some hook anchors so that I can still use the room. Then I can just back my Bronco in under it for parking. That would also make it easier to put it back on by myself; I could lower it onto the bronco.
Great info. The tire thing will work great for now. I am looking at the trick of hanging it when I get the garage re-arranged. I will use a small boat winch to lift it and have it designed to back onto the lift mechanism and unbolt the top and remove it. Then add a safety cable to the front side of the bars that suspend it.
Thanks for the input.
Originally posted by BroncoRoadKill
If you hang your top from the ceiling, you might want too put a couple 2x4s under it and tiethe ropes too the board, that way you don't spread the sides.
kys911t
12-31-2016 04:45 PM
billyb
02-19-2002 02:52 PM
