Underheating engine
Old 12-14-2003, 08:21 PM
grey169's Avatar
grey169
grey169 is offline
Underheating engine
I have a 1.9L engine and it isn't heating well. The problem is the engine won't get to Normal on the temperature gauge. I figured since it was an older vehicle it needed a new thermostat. I replaced it tongiht and it did the same silly thing. Any one have any suggestions on what it could be?
I can get the temp in the Normal area of the gague by sitting at a high idle (3000 RPM) and sitting for about 5 mintues. I take it out on the road and it cools back down to where the needle is below normal. I need help! It is cold in Wisconsin!!!!
Old 12-20-2003, 01:07 AM
AlfredB1979's Avatar
AlfredB1979
AlfredB1979 is offline
I tried to replace the t-stat in my 94 2.3L truck, but I had to give up on that thought. I would get the radiator cap tested. If it doesn't hold pressure, you obviously won't get a temp increase, either.
My truck will warm up eventually, but idles crummy at cold start-up and smells a little rich. My t-stat checked out okay, btw....temp gauge works, but doesn't move muh past the left "\" mark well to the left of "NORMAL".
Old 12-21-2003, 01:13 AM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Is it the 1.9 in an escort? With mine, the coolant change, and t-stat fixed it. The only real way to know if it is underheating, or if the gague is just off a little is to put an aftermarket water temp gauge in.
Old 02-22-2004, 05:43 PM
danny waterman's Avatar
danny waterman
danny waterman is offline
I had the same problem with my 1991 2.3 just the other day. I changed the t-stat and it was the same, I tryied a new cap and it solved the problem
genscripter
07-07-2015 11:18 PM
shayne.jacques
03-31-2015 11:34 PM
normco
06-08-2014 07:03 PM
upnorthman
01-07-2013 09:50 PM
klemmy
1997-2006 Expedition & Navigator
01-05-2009 04:43 PM
Quick Reply: Underheating engine
