'Lights on' chimes when lights are off
I know that this is going to sound silly, but are the keys still in the ingition when you are trying this? I can not recall what my Mountaineer does (and it's too cold for me to run out there right now ) but I am pretty sure that if I leave the keys in the ignition when I open the driver's side door it chimes at me to remind me to take them with me.
While not 100% about the Mountaineer I know that my Mazda most certainly does this.
I do not think the question about the keys is odd. I troubleshoot electronics for a living, first law- Check the power plug, second law- check the power switch, third law- check the fuse. Then troubleshooting starts in earnest. Yes, this is with the keys removed. It will ding if you leave the keys in as well.
I will check the headlamp switch. I had replaced the bulbs in the instrument cluster about 3 weeks before this started happening. Maybe the connector is loose? I do not know what the GEM module is. Could you please elaborate?
Thanks,
Paul
Thanks,
Paul
