98 Expedition Washer Fluid Leak
Just a note to let anyone who is loosing washer fluid and can't find a leak.
Look under the passenger side door jam and kick panel, there is a hose that feed fluid to the rear washer.
mine popped off a connector and leaked two gallons into the channel under the door jam wher the wiring harness is !
Vac out and use cat litter to dry !
