Battery drain
Old Feb 12, 2004 | 12:04 PM
TrailsEnd's Avatar
TrailsEnd
Battery drain
I have been trying to trace a battery drain problem. When my truck is off, I have a 400mA constant drain on the battery. I removed every fuse to try to determine which circuit is causing the drain. That didn't work, so I started to look under the hood at the fuses and relays. When I removed the fuel pump relay, the drain current went to 0mA. Does anybody have any ideas as to what could be causing this... A fuel pump? Fuel safety cutoff switch? The truck has dual fuel tanks and three fuel pumps.
Thanks,
Mark Walter
mark.walter@sciatl.com
1991 F150 XLT 5.0 2WD
Old Feb 12, 2004 | 08:26 PM
92Thunder's Avatar
92Thunder
try unplugging the ignition switch and see if it goes away. it worked on a 79 iI had to work on. I realize yours is much newer, but the Ign switch still controls that fuel relay
