351W rebuild woes
351W rebuild woes
Howdy!
Finally got my engine back from the mechanic and put it in. Having timing problems though. 92 F-150, 351W EFI.
Like I said, I got it put in but it wouldn't start right up. Acted like timing was off. I adjusted the timing enough so it would even start, but was running really rough. Also popping back (I could tell because evidently I didn't get the new shorty headers tight enough to the factory y-pipe.)
Anyway, I put the timing light on it and it was way off. I know at idle (650 rpm) it's supposed to be 10 degrees BTDC. It was running at about 20 degrees ATDC! I don't even know how it was running at all. When I tried to back it down, when I got close to zero, it would die. Anything 0 or BTDC, it won't run.
Yes, I made sure #1 cylinder was all the way up on the compression stroke when I put the distributor back in. And yes, I aligned the rotor with the #1 position on the cap.
A little about the engine. As far as I know and what the mechanic tells me, it was completely stock, never had a wrench on it. Now it's .030 over; slightly bigger cam (CompCam, not sure of specs. Mechanic says it the biggest the computer will work with, very mild); and shorty headers. That's all.
I'm not sure where to go from here.
Well, after a little more blood, sweat, tears and four-letter words, I finally got it running right.
It's amazing how bad a couple of ripped open plug wire boots and a distributor that's one tooth off will make your engine run.
I ended up buying some new plug wires (accel). The old ones had only been on there for about 2 months before I pulled the engine. Guess I must have ripped them when I was taking them off without noticing it. Also, that distrbutor is a bear to get set in exactly the right spot. I had to pull it out and turn the oil pump shaft a tiny bit at a time until it would let the distributor line up on the cam gear exactly where I needed it. Darn near lost a deep 3/8 socket down into my timing gear set! OUCH!! That would have sucked!
Anyway, she's purrin like a kitten now...that is...a kitten with a bad case of gas. Gotta see if I can get those Flowtech headers to quit leaking!
Thanks for all your help guys!
