3024 speed to 429 swap
i have a 90 f1504x4 with a 302 4 speed with creeper gear and would like to put in a 69 429 that i have but would like to keep the 4 speed have changed from a 8.8 to a 9 inch and have a 6 inch lift in would like to know what i need to do the swap i am also ditching the efi and tfi ignition will be running a duraspark
The 302/351W bellhousing bolt pattern is different from the 429/460 pattern. You may want to check to see if an adapter is available or maybe custom made. You will need motor mounts from an F250 with the 460, as these are different as well but should swap right over. An alternative would be a C6 with the 429/460 and 351M/400 bolt pattern.
