AOD vs E4OD
Old Feb 8, 2004 | 12:11 PM
geokel1014's Avatar
geokel1014
AOD vs E4OD
Was looking at getting a donor veh with a 302 MAF and an AOD tranny to upgrade my 91 F150 302 SD. If I swap the motor complete with MAF and the computer will this work with my E4OD or would it be better to swap tranny also? Which is a better tranny for a truck that will have a little bit more that stock power/torque? My other option was to keep the SD and E4OD and just build off the donor block. Any help?
Old Feb 8, 2004 | 12:34 PM
StrangeRanger's Avatar
StrangeRanger
The E4OD requires a compatible PCM. You cannot use one from an AOD
Old Feb 10, 2004 | 09:27 AM
geokel1014's Avatar
geokel1014
Thanks. Would it matter which tranny I use provided I have a compatible PCM? Which tranny is better?
