Oil & Lubrication
Grease Question
Old Feb 7, 2004 | 12:30 AM
Bronco2Nic's Avatar
Bronco2Nic
Question Grease Question
I'm finally putting my engine ('85 2.8L V6) back together and i'm wondering which lubricant would be better to use. I dont want to buy any new stuff so I have two to choose from. there is
A) White, Lithium based grease
or
B) Black, Oil based, Bearing grease.
that you for any help
Old Feb 7, 2004 | 01:12 PM
peppy's Avatar
peppy
This Ronex MP is a high end product with a decent price. I've been using it without a complaint yet. Its a lithium complex.
Give the link a look. It is pretty indepth and self explanatory.
http://www.exxon.com/USA-English/Lub...SEXRonexMP.asp
Old Feb 7, 2004 | 03:45 PM
oppy's Avatar
oppy
Are you talking about just for engine assembly?? You'd definitely want to use a different product for engines than you would for wheel bearings and front end parts.
Old Feb 8, 2004 | 06:37 PM
68torino's Avatar
68torino
I believe white lithium grease is only indicated for cam shaft lobes if you don't have cam lube. Otherwise I have seen where 30 wt oil is used for the bearings.
Old Feb 9, 2004 | 10:11 AM
jimandmandy's Avatar
jimandmandy
I assume you are doing an initial fill with cheap oil and drain it after a short time. I just use SAE 30 as an assembly lube today, but I used to do what you are doing with whatever grease I had on hand.
Jim
