New To Forums. Have some questions.
Hi, I'm new to the forums here. Glad I found them! I have a question about the axles in my Excursion. The tag on the rear end reads as 3 S 410 A. I would assume the 410 means 4.10 gears, but I didn't think the Excursion could come with 4.10. Also, can I tell by this code if the axle is limited slip or not? Thanks in advace for any and all imput.
Re: New To Forums. Have some questions.
Originally posted by QuickSilver
.... but I didn't think the Excursion could come with 4.10. Also, can I tell by this code if the axle is limited slip or not?.
What code is on your door? You can tell both the ratio and presence of an LS unit by it.
Quick,my sticker is on the pillar down by the seat controls on the drivers side.It has a bar code and various listings for wheel base,brakes,axle,etc. I was happy to find out The X we just bought has a limited slip back there!!! Should make pulling our boat out on slimy ramps a little less dramatic!!!
Yep, I found those. Thanks anyway for trying to help. I stopped it by the ford dealer today and they had a lot of trouble finding the right codes too. Turns out it has 4.10 gears and no limited slip, or so they tell me. They figure it has no LS because they say that if it did, it would say on one of the axle tags that it requires some sort of an LS addittive for the oil. it does not say this so, well, there you have it. I dunno if they are full of crap or if they know what they are talking about.
if you have a V-10 it was only available with 3.73 or the 4.30. the 5.4 v-8 came with 3.73 or 4.10. The 4.10 was the only way you can get a limited slip with the v-8. If yours truly is the 4.10 I would check with a dealer near you and have them check the vin #, they can input it into a computer and tell what axles it should have come with. It is possible that a previous owner(assuming you bought it used) may have switched them out with a superduty truck. Good Luck
Toyman
Toyman
Listen, I know it can be a pain in the *** to do it but you can definitivley tell if you have an LS unit by jacking up the back axle. If you read the FAQ it'll tell you how.
Plus to determine gears just simply note the speed you travel while in OD and do the mathmatical calculations or, again, refer to the FAQ in the SD section.
I'm going to wager $1 that you have a 3.73 with a LS. It is the most common rear end gear put in the Excursion Limiteds.
