1x4 ?
Old Feb 5, 2004 | 09:01 PM
95f150's Avatar
95f150
1x4 ?
Just wondering:
Having an open dif in the front and rear would actually be 1x4 in 2wd and 2x4 in 4wd, Correct? Anyone know where i can get a ls or a locker for my rear 8.8" Want cheap but reliable.
Thanks
Old Feb 5, 2004 | 09:04 PM
SoCalDesertRider's Avatar
SoCalDesertRider
That's correct. Try www.ring-pinion.com or www.precisiongear.com or www.offroadwarehouse.com or www.4wheelparts.com for differential sources.
Old Feb 5, 2004 | 09:38 PM
oldhalftons's Avatar
oldhalftons
if you have a np203 (or other full-time Tase with a open dif in it) and open difs at the axles, Yes it is possible to have 1 wheel drive.
thats why a NP203 has Lock positions in high and low. to lock the transfer case and send power to the front and rear evenly.
it is NOT possible to have 1 wheel drive with a part-time transfer case.
Old Feb 5, 2004 | 10:14 PM
MustangGT221's Avatar
MustangGT221
Well, to be more specific..its only 2wd (in 4wd) when tires are on uneven tractioned surfaces...if all 4 tires are on the same traction surface, they will all recieve power.
